I'm going to be doing a job that requires a 2" diameter hole, 5 1/2" in length (Through hole). The material is 6061 aluminum. I have a Boring Head but the longest bar is 3". If possible I would like to avoid boring from both ends. I was wondering if this bar can be used with a boring head? >>bar<< If so what would you recommend as a tip for 6061, with or without chip breaker grooves? Also what lead angle would be best for aluminum, -1* or -5*? |
| i can't see why you couldn't do it with a boring head, except that a 1/2 bar with 5" of over hang seems like a lot - it'll work but with light cuts and very fine/no feeds cuts before measuring to work the spring out. You'd be better off with a carbide boring bar (less flex) but its still not an ideal length to dia ratio (iirc 5 or 6x). All this assumes the 1/2" comes from the size of bar your boring head will hold. If the part allowed it, i'd do it in the lathe with a larger dia boring bar. Last edited by Mcgyver; 06-30-2006 at 10:23 AM. |
Would you suggest just boring it from both ends. |
| I recently used a boring head with carbide tipped tooling to bore a 5.25" hole, 1" deep in 6061. I broke some of the rules by raking the bar back by about 3 degrees (a guess) and I honed a small radius (maybe a 1MM radius) on the tip for the finishing cuts. I started with a 1" drill, then plunged with the largest end mill I had which was a 1.5" rougher. I then hogged material from there manually plunging the cutter in a pretty hap-hazard fashion to get the majority of the material out of the way using a scribed line as a visual reference. Once I got most of the material out of the way I switched to use the adjustable boring head and positioned an old boring bar on the OD of the boring head. When I got close to size, I switched the cutter to a more rigid bar and took fine cuts from there. It took a bit of time, but I had no issues with finish cutting. This was prior to completing my CNC - now I would interpolate then true it up with the boring head. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| I read right over that without really thinking about the length/diameter relationship - sorry! Carbide bar or light cuts is all that comes to mind at the moment. I guess a reamer is out of the question (cost). Another option would be to get your hands on a smaller diameter boring head that would allow the head itself to go into the hole - then you would be set. Something like a DeVlieg boring head as shown below. What machine are you doing this on? Do you have enough quill stroke? Scott
The hole actually has a capped end. (sort of like a U-joint cap on a drive line) So I do have some room for deflection on the bar. What kind of tolerance might I expect with the bar I linked here? I'm going to take 2 separate pieces of stock and drill and tap the 2 sides, then bolt them together. Then I'll bore the hole between the two pieces. There will be another part that will be "sandwiched" between them. I can always mill a few thousands off one of the halves if the hole is a little off. I guess I didn't really give enough information with the original question. I guess really what I was asking was if the bar was suitable for a boring head and what lead angle and tip should I buy for aluminum? Being new to machining (and self taught) I always assume I'll end up buying the wrong tool for the job.... |
| I think the bar you have will be fine. For aluminum (right or wrong) I use a positive rake tool with a small corner radius and I use Tapmagic for finishing cuts to improve the finish quality. The bars I use the most are cheapies that have a neutral face so I cheat by grinding a bit more radial clearance and rotate the tip forward to falsely create a positive rake. For finish cuts, I use .001" per rev downfeed at a relatively slow RPM to eliminate vibration from the cutter being off-center. I am thinking around 500RPM or so. Scott
#12
| well I going to be "that guy" and say the obvious an since you are new..... Use the force luke use the force!
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
