| Can you cut Al. with a wood bandsaw I have several little projects that would benefit from quick "roughing" to shape by a bandsaw. The shapes are cut from aluminum plate ranging from 1/4" to 1/2". Would a cheapy 12" bandsaw, with very slow feed rates, cut this metal? Or would I be better off saving for one of the bigger rigs that tilt and cut pipes, too? Are there any other ways to cut profiles from plate aluminum (without breaking my student's budget)? Anything has to be better than the hacksaw I've been using... Thanks |
| I do all the time alum is as soft as wood.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Thanks, I'll pick one up this weekend at Harbor Freight or Sears. Do you use lubrication on the blade while cutting? |
| Yes, you should pick up a wax stick for metal and apply it to the blace every once in awhile. It helps to keep the chips from sticking to the blade. I use it on my bandsaw and my power mitre box when cutting aluminum |
| The fastest way I have found to cut aluminum and copper is with a power mitre saw with a carbide tipped blade. I've got a 7" saw that works well for most barstock under 4" wide, and a 14" for larger stuff.
__________________ My name is Electric Nachos. Sorry to impose, but I am the ocean. http://www.bryanpryor.com (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I purchased a metal cutting blade for my band saw at Sears and it works just fine. Never tried the wood cutting blade. Hager |
| Kcam Cut depth | 47MLB | Kellyware CAM | 6 | 01-18-2012 02:04 PM |
| Sand/Bead Blaster wood cutting | DDM | DIY-CNC Router Table Machines | 13 | 12-27-2004 09:12 AM |
| cut single, cut auto and cut all??? | fastolds | BobCad-Cam | 3 | 10-06-2004 09:15 AM |
| PICS - BOAT HULL CUT WITH CNC | ninewgt | DIY-CNC Router Table Machines | 16 | 08-02-2004 07:21 PM |
| Bandsaw accuracy? | gtslabs | General Metalwork Discussion | 3 | 12-29-2003 10:26 PM |
