Old 06-06-2006, 03:24 PM
jlembas is on a distinguished road
large diameter end mills??
Searched the forums, but couldn't find anything.
I am looking for large diameter end mills. Somewhere in the neighborhood of 2" through 3". Is this possible? I assume I'll have to get them custom made. Any help would be appreciated.
Old 06-06-2006, 03:44 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
http://www1.mscdirect.com/CGI/N2DRVSH?PMSECT=717
They are standard shelf items at MSC Supply!
http://www.mcmaster.com/
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 06-06-2006, 03:57 PM
*Registered*
lakeside is on a distinguished road
the size you are looking for are also can be insert type cutters which can save in long run with regrind cost and loss of tool dia and lenght
Old 06-06-2006, 04:17 PM
Thanks guys. I don't know how I overlooked MSC. Anyway, I'm going to be coping large tubing with these things so the indexed versions probably won't be needed.
Old 06-06-2006, 04:57 PM
*Registered*
why not look at a shell mill if your looking to just form end
Old 06-06-2006, 05:40 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Shell mill, annular cutter or a hole saw.
www.integratedmechanical.ca
Old 06-07-2006, 01:43 PM
Conicity_Tech is on a distinguished road
For large diameter endmills go to eEndmills.com and fill out online request form or fax/email details...Steve L.
Old 06-07-2006, 07:43 PM
I'll look into your suggestions. We already have hole saws, but they just aren't working out as well as we would like. Some of the parts that we are coping are solid machined pieces and some are long as well. We are dedicating a horizontal mill with a vised jig to run the parts so that is why I would like an end mill or some variation. I am hoping to get a more precise and cleaner cut with the mill setup. Thanks to everyone for helping out.
Old 06-07-2006, 09:12 PM
Steve@Reliance is on a distinguished road
Cutters
I use milling cutters for coping tubing from 1-2". One thing you should seriously consider is using roughing end mills. They reduce chatter and the tendency to grab tremendously. Finish quality is more than sufficient for tig welded joints.
