Old 05-27-2006, 05:01 AM
derkiow is on a distinguished road
surface speed and feed rate calculator
hello forum has anyone got calculator for determing the surface speed and feed rate of emd milld and slot drills please something that easy to use and on the internet ,,,,,all the best derkiow
Old 05-27-2006, 06:22 AM
Gold Member
Ken_Shea is on a distinguished road
It is not free but it is the easiest to use I have found, it would be extremely useful for any level of machinist experience.
Inch or Metric selection.
Much more then speeds and feeds as well.
Well worth considering, you can take a look at what it has to offer here.
http://www.mrainey.freeservers.com/
Old 05-27-2006, 07:09 AM
*Registered*
lakeside is on a distinguished road
I use ME Pro the program Ken Shea is talking about the feed and speed are very good starting point. Also you can edit data base for tool and materail it's about $100 but you can save that in endmills,drills and scrap peices in not time. I find that it's something that I use just about every day
Old 05-27-2006, 05:32 PM
Kiwi is on a distinguished road
Here is a simple VB program that I have written.
It is very basic and use only as a guide.
Old 05-28-2006, 01:28 AM
Thumbs up a big thankyou
a big thank you for your help , calculators very useful and easy to use
Old 06-02-2006, 09:31 AM
Miguelflores is on a distinguished road
surface speed in mdf
hi.
i have the same problem, but i need calculate the surface speed and feedrate in mdf. and i only find for metal materials. if you can help me, please. any way tank you.
Old 06-02-2006, 04:44 PM
Miguel
I can add MDF.
What is the recommend cutting speed and feed?
Is there different grades which requires different conditions?
Old 06-03-2006, 06:15 PM
Angry conflicting information found.
MDF added to calculator.
Chip load is set at minimum .008in. maximum .016in.
New version attached.
As I have found conflicting chip loading information I have withdrawn this version of the calculator.
I will modify and repost. Sorry for any inconveniance.
Last edited by Kiwi; 06-03-2006 at 11:14 PM. Reason: conflicting information found.
Old 06-04-2006, 02:16 AM
Thumbs up
Chip loading is set at minimum .001in. maximum .012in.
Revised version attached.
Old 06-04-2006, 07:33 PM
Muzzy is on a distinguished road
I hope this work. I have a attached a speed and feed Cal.
