Old 05-19-2006, 10:55 PM
nitrosnfr is on a distinguished road
canned drill cycle
can anyone give me a canned drill cycle for pecking with a live tool.machine is a mori seike sl25 with a msc-516 control. any help appreciated
Old 05-23-2006, 07:40 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Arrow Canned Cycles for Drilling With Live Tooling
I'm not sure what kind of control that is, but this may give you some ideas.
Fanuc 1LE Control for a TSUGAMI Swiss Screw Machine
G0X1.5M5T0
/M8
(DRILL .089D #43 ROLL TAP 4-40 CROSS)
N10T0303
G50W.25
M81
S2000M113
G0X.275Z.25
G98G1X-.277F3.0
G0X.275
M115
G99X1.5
M30
OR
G98G0X.275Z.25
M70
S2000M113
G173X-.277R.01Q.04F3.0
G80
M115
G99X1.5
M30
Canned Cycles can be Tricky. Most of it depends on the original Options that came with the Control Software.
The first code that I wrote is the original and the one after was an upgrade that the company purchased later.
I Hope this gives you some ideas on where to start. Maybe you can play a little and try some different things to see if you can get started.
tobyaxis
Old 05-24-2006, 10:50 AM
The control I think is a Fanuc as it is very similar to rest of the sl25's.It just doesn't say on the control panel.
On one of the other lathes which is a Mori Seiki SL65 the drill cycle is written this way
m45
go c0.
go t1201
g97 s2500 m13
go x5.0m8
g98 g83 z-.75 r0. q5000 f10.
L11 H30
go g80 z1.0m9
The 2 machine controls are identical as far as I can tell.
Trying to help a fellow worker out with this.Thanks for the idea.
Rather odd the way the SL65 will run it.
Also odd the basic cycle is the same on the Mazak Integrex that I run.
