Old 05-19-2006, 10:13 AM
Flyinfool is on a distinguished road
Measuring Gears
I need to make some gears for a project.
I have the correct cutter and have an indexing head for my mill.
I need the formula to calculate the wire size and measurement over wires.
The gears that I need are 13 and 14 tooth Module 1, metric gears.
I have searched all over the internet looking for this and have not found an answer. The closest that I found was a chart from SDP/SI but it only goes down to 18 teeth.
Or is there another way to determine if I am cutting to the correct depth with out spending major $$$ on a gear checker
Any help would be appreciated.
Jeff
If it aint broke, fix it till it is.
Old 05-19-2006, 10:32 AM
HuFlungDung's Avatar
Moderator
Machinery's Handbook has this information. It is too complex to relate on this forum. The old 20th edition has an actual formula, the 25th edition has a bunch of preworked tables.
Old 05-19-2006, 10:39 AM
Gold Member
Ken_Shea is on a distinguished road
Jeff
This may offer some help, all dutch to me though.
http://www.shopswarf.orcon.net.nz/module.html
Ken
Old 05-19-2006, 06:29 PM
Kiwi is on a distinguished road
Gears of module 1 and less than 17 teeth become undercut.
Your cutters may be ground to prevent undercutting.
These figures are for a for 20deg pressure angle and true profile.
Module 1: 13 teeth: Pin dia 1.75mm: 1 pin = 15.217mm: 2pins = 15.335.
Module 1: 14 teeth: Pin dia 1.75mm: 1 pin = 16.22mm: 2pins = 16.44.
Check with existing gear.
This site has a download program.
http://quickgear.bizland.com/index.html
Old 05-23-2006, 07:58 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Lightbulb Gears
Did you try searching Gleason Works?
They produce machinery and cutters specifically for all kinds of Gears.
You can also try Fellows, Micron, Parker and Barbra Coleman.
A great source may be AGMA. This is the classification of Gears and Tolerancing Classification.(Association of Gear Manufacturing)
Started out working in a Gear House making AGMA 12's and 13's (+-.0002). After this Class Gears have to be Ground AGMA 14's and up.
The Machinery's HandBook #18 is the best for Gears. It explains about Addendums, Dedendums, and Pressure Angles. Way too much info to list in this Thread.
tobyaxis
Old 05-24-2006, 03:02 PM
Thanks to all that answered.
I had started by looking in my Machinery Handbook #23 and did not find what I was looking for.
Kiwi
The link you posted worked out great.
Thanks again.
Jeff
