Old 05-10-2006, 06:36 PM
Gold Member
bgolash is on a distinguished road
Tapered Pins for alignment of spindle plate
Hi all
I am nearly done with my 3 axis router|mill. I`m thinking about using a router motor instead of the current setup which has a plate of aluminum which has the motor, motor mount and spindle all attached. I`m looking for the most accurate way to drill and ream some alignment pins into this assembly. If done correctly this should allow me to change from the spindle to a router and maintain some repeatability for the spindle.
I`ve been to MSC to locate tapered pins and the correct reamer to match. Can`t seem to find any tapered pins...does someone have a source for these items.
Thanks alot!!...Barry
Old 05-10-2006, 07:42 PM
StealthDumpKits is on a distinguished road
Try http://www.mcmaster.com/
Factory type pins usually have internal threads so you can use a puller to remove when bent. Normally installed in blind holes. Very good idea to use taper pins for alignment purposes. A gentle hand reaming before insertion is my rule of thumb (pun intended).
Old 05-10-2006, 08:37 PM
2muchstuff is on a distinguished road
http://www.carrlane.com/Catalog/inde...1E173C1B085355
These guys have a lot of tooling components.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
