Results 1 to 4 of 4
Thread: how to remove lead screw in Kurt Vise?
    Jun 2005
    i am rebuilding a KURT 675 vise and i've got it disassembled i just can't seem to get the lead screw out. does it come out? i guess i can clean and paint around it.
    Jul 2005
    I have taken apart a different model Kurt but they probably have the same retaining clip on the screw. Look where the hex end comes out of the base casting there is a retainer clip there. It is not like a regular circlip with little tabs and holes it is like a multi turn flat spring. You should be able to see a little concave arc on the inner corner of the end of the spring and you can get under this with a tiny screwdriver and pry it up then work another screwdriver between the part of the ring that is above the groove and use the two screwdrivers to work it out all the way around. It is fiddling and you have to be careful not to strain the ring too much in any single location because it will bend or break.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    ^Exactly as Geof says^
    www.integratedmechanical.ca
    Jun 2005
    i got it out and the whole vise rebuilt thanks for the help.
