04-20-2006, 02:27 PM
I like ZipSnipe's suggestion the most as it does reflect the reality of that business. Free wieghts do have thier place also.
If it was me I'd strive for a couple machines instead of one to cover every single excercise you can imagin. Assuming you are familiar with gyms, model equipment based on what you see there. I would start out with a Smith machine clone of some sort with an independant bench or multi purpose bench. Then I'd build a seperate bench to do leg lifts and curls on, maybe making it a combo to do preacher curls on.
After that go on from there with what ever suits your interests. In all the machines above do take into consderation safety.
As to cable and wieghts I personally am opposed to that sort of design. You probably could manage such a machine if you have a lathe to turn the parts but that isn't my real concern. There are a couple of problems with these machines in my opinion anyways. One is that you have all your wieghts tied up in stackes that are not easy to use else where. The second item is that the cosntant fiddling with setting up the machine really impacts the work out negatively. Third they just are not as reliable as well designed individual machines.
Some of the problems with the so called unirversal of multi machines can be dealt with, if the scope of the machine is limited and it is designed to use standard weights. So for the most part I wouldn't model it after such a machine. Give me a couple of well designed machines with the material you have. I actually think your material may go further this way, at least some of it anyways. Of course finding the room for the equipment is another execise altogether.
Oh by the way do take time to think about engineering with these machines. There is a lot of force potential in 500 pounds or what ever you are pressing if something should go wrong. A bent frame is one thing but a sheared pin could be hell to pay if you are underneath the bar at the time.
Dave |
