Old 04-10-2006, 09:06 PM
rcazwillis is on a distinguished road
Turning Tool Steel
I purchased a 3/4" screw length drill bit. I did not expect the shank to be 3/4" also. I have a 5/8" chuck. How do I turn down the shank to 5/8"? I have a 7x lathe. Do I have to grind the shank or will standard tools cut it?
Old 04-10-2006, 09:13 PM
Traceycnc300 is on a distinguished road
I have cut the shank down on several drill bits with carbide inserts with little trouble but the lathe I was using was heavy duty.Dont think youll have much of a problem if you take small cuts.Make sure its running as true as possible.Use collet if you can.
Old 04-10-2006, 09:14 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Carbide will cut it - no problem. Drill shanks are typically a bit softer than the flutes.
Good point about ensuring it is running true!
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 04-10-2006, 09:34 PM
ViperTX is on a distinguished road
yes, I turned down some bits for a friend....carbide cut through the shank without any problem on my 8x14 lathe.
Old 04-10-2006, 10:15 PM
Thank you. I will try it this week some time.
Old 04-11-2006, 12:46 AM
WhiteTiger is on a distinguished road
I've had good luck using just m42 cobalt bits. Especially on larger drills (3/4 to 1 3/4 is the range I've cut) the cutting is easier than with carbide (imo) and the resulting finish is very nice.
Tiger
Old 04-11-2006, 04:06 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Drill shanks are normally quite soft, as they are not tool steel. A plain steel shank is welded onto the HSS fluted portion. Think of how easily they burr when they spin in the chuck. You can turn them easily with HSS in my experience.
Regards,
Mark
www.wrathall.com
Old 04-11-2006, 08:35 AM
JPMach's Avatar
JPMach is on a distinguished road
If you have a collet chuck it will usually run pretty true too. As Rotery said the shanks are not tool steel but just soft steel like a 1045 or so, turns very easily with regular tooling.
JP
