Old 03-31-2006, 08:39 AM
RayDOsity is on a distinguished road
Question Need FANUC NURBS info
I'm looking for anyone with experience using the NURBS function on the newer FANUC machining-center controls. Are G-codes still used and if so are there any that are specific to NURBS machining? As far as CAM systems go, which ones are best for using with NURBS machining?
What kind of post-processing/if any needs to be done on your run of the mill (non-NURBS) CAM system output before it can be used with FANUC's NURBS function?
Shine on,
RayDOsity
Old 03-31-2006, 09:20 AM
*Registered*
lakeside is on a distinguished road
Well if your doing NURBS your doing some advanced programming NURBS are stander EIA format from cam software you can use any software to get the basic code needed Then I would run though a second software from Metal Cut for more precise code here a link to a site for demo Metal Cut Finish/Pro
http://www.nwdesigns.com/
