Old 03-14-2006, 10:58 PM
Siress is on a distinguished road
Titanium sliver embeded in hand... Help.
I've just recently started working with titanium and have discovered something interesting but painful. As the title states, I've got not one but TWO tiny slivers of titanium embedded in my hand that occasionally hit a nerve when I move my hand the wrong way. My question is how do I go about remedying this problem? I hate to go to a doctor about it unless I have to. If I had to describe the feeling, when it hits the nerve, it's like having a long needle hammered through the bone. Now imagine that initial pain of the needle hitting your nerve being repeated several times...
So what have you guys experienced like this and how does one go about remedying the situation?
-Siress
Old 03-14-2006, 11:15 PM
I don't have a particular suggestion about how to get the slivers out but I did check a website about titanium and tissue compatibility and found this;
"titanium, perhaps the most biocompatible material known".
So you can be reassured that titanium is not going to give you any horrible reactions so your problem should not progress beyond feeling like needles being hammered into your bones.
Old 03-15-2006, 01:23 AM
unterhaus is on a distinguished road
I'm really bad about slivers, I just start cutting away with fingernail clippers until the sliver is gone. I don't have any permanent damage anywhere, the flesh will grow back. Metal slivers are the worst for annoyance.
Old 03-15-2006, 11:45 AM
2muchstuff is on a distinguished road
Do you drink and do you have someone you can trust with a knife and tweezers.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 03-15-2006, 01:22 PM
bcromwell is on a distinguished road
Razerblade and self surgery..
Old 03-15-2006, 02:11 PM
Yup and a bottle of Jack Daniels.
Old 03-15-2006, 02:57 PM
bill south's Avatar
bill south is on a distinguished road
Once upon a stupid time when I was first learning to use my bench top, I reached out and in all my glory, dusted freshly machine slivers of steel to the side so that I could inspect my cut. Does this sound familiar????
Low and behold, much of the "dust" did not fall to the ground but was embedded in my hand. Thus, tweezers, sour mash, nail clippers, and many other specialty tools were used over the next week or two to remove part of that "dust". A costly lesson learned! To make matters worse, just when I thought I had removed all the tiny little critters, I would touch something and the demon would return!!!! Short of haveing an MD dig them out, I could not find a good solution to the problem. Although, the sour mash helped and over time, some feastered and fell out and finally, the demon moved on. Like one of my South Carolina co-wokers once said to me: "It's gonna be auite"
Take Care!
billyjack
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 03-15-2006, 03:07 PM
WhiteTiger is on a distinguished road
An old remedy for pulling buried thorns and splinters is a poultice of freshly grated potato wrapped in wet cheesecloth. Apply as often as convenient for around 10 min per app. Usually takes a couple of days or so for the splinter to work up enough to dig out.
Works great for pulling infection too. Cleared up a persistent eye infection I once had after weeks of assorted antibiotics failed. The poultice took 3 days.
Tiger
Old 03-15-2006, 09:02 PM
I would've cut it out but I can't see them, not even an entry point. And the pain isn't focused really, I can barely tell which side of my hand it's on. Thanks for the tips guys, I guess I'll wait it out a couple of days and try the potatoe thing if it doesn't work its self out.
Most of the chips are huge...
Old 03-15-2006, 09:05 PM
ViperTX is on a distinguished road
Pull the slivers out and start wearing protection....
  #11   Ban this user!
Old 03-20-2006, 08:14 PM
Dawson's Avatar
Dawson is on a distinguished road
This has always worked for me, just make sure to wash the area with alcohol and hydrogen peroxide after digging. Usually the fingernail clippers have more infection causing organisms than the piece your trying to remove.
Old 03-20-2006, 08:24 PM
*Registered*
lakeside is on a distinguished road
are you sure that it did not happen at work?
