Old 03-09-2006, 05:39 PM
Zumba is on a distinguished road
Drilling 1/4" Steel
How does one go about drilling holes in large pieces of steel? I'm working with 1/4" thick steel between 6 and 12' in length, too long to drill on the milling machine. A punch won't work when i'm drilling square tubing and such.
I've seen those drills with magnetic bases, but they don't seem to be appropriate for drilling smaller holes.
I'm willing to spend up to $1k, as I'll probably be using this tool frequently. Thanks for any suggestions.
Old 03-09-2006, 07:52 PM
Karl_T's Avatar
Karl_T is on a distinguished road
A radial arm drill press would be wonderful for this application. They come in all sizes.
If you want something portable, there's no reason a magnetic base drill wouldn't work.
Karl
Old 03-09-2006, 10:23 PM
keebler303 is on a distinguished road
i have used a milwaukee mag drill for all kinds of stuff and it is great. the chuck only goes down to 3/16 but we took a chuck out of a dead cordless drill so we can chuck the cordless chuck in the mag drill chuck and use bits down to 1/16. i have personally used bits around 1/8 and it works great.
Matt
Old 03-10-2006, 12:40 AM
Thanks for the replies.
The websites that sell the mag drills say it's for 1/2" steel or thicker, but apparently 1/4" is just fine?
Old 03-10-2006, 01:10 AM
WhiteTiger is on a distinguished road
One quick and dirty way to do it is turning the head of a bench model drillpress upside down on the column. Stick it under a table with a hole in it and drill upwards. You can drill in the middle of any size or length workpiece you can support.
It can be fun positioning for the holes, but a plumb bob suspended from the ceiling dead center over the spindle takes care of that.
Tiger
Old 03-10-2006, 03:09 AM
One of Many is on a distinguished road
deleted
Where is the delete button? The little red X says I do not have permission to access that feature?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 03-10-2006, 03:23 AM
deleted
Old 03-10-2006, 03:38 AM
The problem with most of them, is that they were made for large diameter drilling. That puts the RPMs below 600, with an average of 450RPM.
Milwaukee does have a base, but that alone is around $900. The drill motor would add another $300-$500 from them. You could mount your own with a higher RPM, I suppose. Not very effective for anything less than a 1/2" bit.
Milwaukee Base
This is more like it, but no price listed.
Comeq M-100D
DC
Old 03-10-2006, 07:33 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Use your milling machine and reposition your part.
If your holes need ro be accurate center to center this is the best method.
Lets say you can drill two holes using the travel of your X axis - do it. Move your X axis back to the position of the first hole -use a pin the diameter of the hole - slide your part down and drop the pin in the last drilled hole - reclamp the part - repeat from the top of these procedures.
Working along this same principle - you can make a fixture with an alignment pin (sized as above) and clamp it to 1 end of the table - have your head beside it the distance of your hole centers - drill hole - slide part untill it fixtures in your drop pin - repeat.
You will need support stands for the overhanging material in both of these cases.
www.integratedmechanical.ca
Old 03-10-2006, 03:18 PM
Rustybolt is on a distinguished road
You didn't specify what size drill, what kind of steel and how wide the material is.
