I hope this is the correct placer to post comthing like this.
I need something like this made maybe jazzed up a bit or just a little cosmeticly different as this is someones elses design and I do not want to direct copy the design. I need this made and is about 1/2 inch long with a 3/8 deep ID of 1/4" and 1/8th deep ID of 3/16ths.
This will be made for an aluminum 3/16th tube that will have a rubber hose slide over it causing the tub to become 1/4 over all. The rubber hose is only on 3/8ths up the AL tube. The 3/16th ID of the back side of this part will need to be (guess-ta-ment) 1/32nd over 3/16ths as the AL tube it will be sliding up and down will be Powder Coated.
I would like to start with 50-100 of these if possable.
Hope this all makes sense
Here is a working version NOT OF MY OWN
