#13
| My inport clone is about to go to the Iron , less than two year's old sound's like a meat grinder when you tighten the thing , the bolt patern isen't the same as a kurt so had to make dedicated soft jaw's dosent repeat wery well and the hex on the handel is sloppey other than that it will make a nice door stop If you want a simple vice I have a couple of BPT vise's I would part with PM me Happy shoping Kevin |
#14
If you buy a Kurt please consider the higher priced models or you may be dissappointed as I was. Even the replacement d675 vise (sent the first one back) which I received was way out of the specified tolerances provided by Kurt for the guide ways side to side clearance -very loose, also much axial play in the thrust needle bearings. Hope you make an informed decision Frank |
#15
| I picked up a used KURT 6" vise from a used machinery dealer, it was all rusty, and the hard jaws were all chewed up! I dismantled the clunker, ran it through the degreaser with a wire brush and some scotchbrite, then let it dry. Re Ground the base, the top of the movable jaw, and the stationary jaw. Then I bought a brand new set of Hard Jaws for it from Enco for $25 each. Now I have a good Kurt viae for under $180! Too lazy to paint it tho! The best part is now I can use all my old soft jaws again! I will still use the 4" Chinese vise, because it is lighter, and easier to load on the bridgeport! Eric
__________________ www.widgitmaster.com It's not what you take away, it's what you are left with that counts! |
#16
| BUY THE KURT D675 !!!!!!!!!!!!!!!!!!!!! www.use-enco.com Hot Deals $394.95 FREE SHIPPING P/N DU425-7760 My 2.5 cents tobyaxis |
