I need to grind or cut notches into carbide cutters (to tighten set screws against),Do I need to get a surface grinder? what kind of cutter could I use to just mill a slot in them? |
| You need a diamond wheel for carbide, a CBN wheel for HSS. If you only have a few to grind for yourself look at Ebay and find a used diamond wheel in good shape. You should be able to find one for a bench grinder. Also is the whole tool carbide, or is the carbide brazed to a steel shank ? |
| Thanks for the info so far. I thought about a diamond stone but was concerned about not getting a flat surface that is square. I want to make sure when I tighten down on the set screw, that it is set against a true flat surface. Maybe I'am making it harder then it should be..... The cutters are solid carbide. I also thought about putting them in v-blocks and mill a flat suface,but not sure what type of cutter to use. thanks for any and all info............. |
| What sort of cutters are you talking about? If it's indexable inserts then you probably don't need a slot at all, since a lot of single point and rotary cutters hold the inserts in place with nothing but screw clamps or wedges. Like most of this stuff, the devil and the solution are often in the details. Tiger |
| The 'green wheel' little_bubba referred to is a silicon oxide grinding stone for your benchtop grinder you can buy at your local tool store for grinding carbide. And beleive me, it grinds carbide like butter! but you sure go through the wheel fast. Jay |
#10
| You don't need a green wheel to put a little flat on. Save that expensive greenwheel(not that bad $60-$100?) for putting radiuses and chamfers on endmills or customizing a lathe insert. They are handy, but I won't walk that 100ft to it for a reason, its expensive and I want it in as nice a condition as it can be for detail work, its very rare that you put a flat on an endmill with any thought as to what the wheel is going through, just stuff it in there and if you beat up an $8 wheel, who cares, you've got your flat. |
#11
| Expensive? I paid $19 for my 6 inch green wheel at house of tools in Calgary. |
