| What is the problem, 303 SS is a soft stainless, which usually taps easily with a two flute spirial point cut tap using brown threading oil! If the print/project allows, simply use a slightly larger drill to make tapping even easier! I would not use a hi-spiral tap, as they are weak and tend to snap in stainless steel! If you choose to use a roll tap, I would suggest using a light spindle oil instead of thread cutting oil, because roll taps displace metal instead of cutting it and need lubrication! Are you power tapping with a tapping head, or hand tapping each hole? Hope this helps! Eric
__________________ www.widgitmaster.com It's not what you take away, it's what you are left with that counts! |
| There are a few factors that need to be taken into account, are we talking about a blind hole or a thru hole. If it is a thru hole a spiral point tap is typically a good choice, if it is a blind hole then a hy spiral tap should be considered. If the tap depth is relatively deep around .30" dp. or more then you should tap drill to the top of the tolerance - see the machinist handbook. A tapping compound as opposed to coolant may be preferable. I have heard that you can use a roll tap in steel but I personally have never done it. In any case, do yourself a favour and spend the extra money to get a tap designed for use in steel, I have had good luck with 'OSG HY PRO TAPS' for all materials. |
