Old 02-03-2006, 11:08 AM
pstockley is on a distinguished road
Measuring question?
Assuming You have a completely flat base (within 0.00015") and you want to align a column about 30" high exactly vertical with respect to a machined/ground face with two reference edges (recessed cut out for mounting a linear guide). What would the best approach be to determine the alignment to about 0.0005" ?
Old 02-03-2006, 01:53 PM
drill is on a distinguished road
laser or the triangle effect
Old 02-03-2006, 04:52 PM
I assume you are not going to let us use a big VMC as a measuring machine.
Make your self a support for your flat base and put three adjustable feet on it.
Get a good machinist's level and a good square.
Find a nice stable surface to work on.
Use your adjustable support and the level to level the base in both directions.
Use the square and level on the column to check that it is perpendicular to the base in both directions.
Old 02-03-2006, 07:14 PM
NC Cams is on a distinguished road
Don't forget to aircondition the room, keep it out of sunlight, don't let the A/C or heater blow on it. Keep the temp as constant as possible - ditto that for the checking gages.
Allow the machine to become thermally stable for 48-72 hours before you start the leveling process - ditto that for the gages.
You may also want to mount in on a big thick deep slab that is NOT connected to the surrounding flooring.
If you're trying to hold tenth's in squareness, even the slightest machining load could knock it out of square. How so??? We've measured 1-2 tenths deflection in 2" dia, 26" long billets by simply resting our elbow on them. Just my $0.02.
