Old 02-02-2006, 02:58 PM
Gold Member
Ken_Shea is on a distinguished road
Carbide counter sink ?
I have several USA made 1/2" 90 degree 3 flute countersinks, they are all carbide, however the cutter is brazed or silver soldered to the 3/8" shaft. My question is, have any of you used similiar cutters for light profile chamfering aluminum or are these solder joints only designed for vertical cuts.
Ken
Old 02-02-2006, 03:19 PM
psychomill is on a distinguished road
Brazed carbide countersinks should have no problem chamfering aluminum.... although I always use chamfer mills...
It's just a part..... cutter still goes round and round....
Old 02-02-2006, 03:23 PM
Sometimes the three flute countersinks have minimal clearance behind the cutting edge to help reduce chatter. Used as a cutter they may rub badly.
Old 02-02-2006, 03:26 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I have, it will work
I also agree with the other 2 guys
www.integratedmechanical.ca
Old 02-02-2006, 05:23 PM
Gold Member
Guys, thanks for the input.
Looks like the answer is, yes it will, but !
Geof, you are right on the money on the clearance, it is there but it ain't much.
Ken
