  #13   Ban this user!
Old 01-30-2006, 05:40 PM
touser is on a distinguished road
I just got done sandblasting for about 30 mins with 80 glass bead and it looks much better. I will have to try the red devil lye on my gas pedal. Thanks for all the help everyone!
*edit* just wanted to show you guys how the pedal ended up looking after it was sandblasted:
Before:
After:
  #14   Ban this user!
Old 01-31-2006, 03:35 AM
greybeard's Avatar
greybeard is on a distinguished road
A final cheapskate method is to boil the aluminium with rhubarb leaves and water.
Don't do this in the wife's best aluminium saucepans, unless you didn't wash the dishes properly last time it was your turn.
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
  #15   Ban this user!
Old 01-31-2006, 07:41 AM
Kevin Taylor is on a distinguished road
The problem with glass is keeping it clean any dirt rust ect will discolor the al. some manufactures of rocker's shot peen 2024 and 7075 with stainles steal shot it's exp!!!
like $5.00 a pound and it would be a must to recycle You would proubley need to step up to a carbide nosel for the blaster but it will give an exlent finish Look at jessel.com or T&D rocker arms and you will see what I mean Vibe finishing mighnt please you also
Good luck Kevin
  #16   Ban this user!
Old 01-31-2006, 07:18 PM
Thanks for the additional tips guys. Regarding the vibrating method, what kind of material would i put into the vibrator and what kind of vibrator would be needed?
Would something like this work:
The vibration idea seems great to me as it will produce a uniform finish.
  #17   Ban this user!
Old 02-01-2006, 07:50 AM
Plastic media works the best Iv found on aluminum there are diffrent shapes and sizes to use depending on the size of part and the desired finish I use a tube tub finisher Its made by topline they have a web site C&Mtopline .com I think. they also have media check McMaster car they have Media too Good luck Kevin
