Old 01-19-2006, 06:31 PM
Gold Member
lerman is on a distinguished road
What is the best way to cut thin wall brass tubing?
I have some thin wall .014 brass tubing 11/32 in OD that I need to cut into lengths (1/4 inch and 1-1/2 inch). I'll need about 1000 of these per year.
What is a cost effective way to cut this that would be bur free? I'm using a tubing cutter now -- it doesn't matter that the end is decreased in diameter, but deburring by hand is a pain.
I could use the tubing cutter with the part in the lathe. Would a tumbler or small vibratory finisher solve my bur problem? I was thinking that a small slitting saw would be a lot faster than the tubing cutter -- but would still have the bur problem and might deform the tubing in a way that I couldn't use it.
The parts will be used as spacers. They must still fit into 11/32 (nominal) holes after cutting.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 01-19-2006, 07:17 PM
Verfur is on a distinguished road
lerman,
Check the severance catolog for inside and outside tubing deburr to be run in a drill press and hold part by hand works great. For cut off might try the lathe and a small threading insert with a good collet chuck and light pressure and very close to the chuck for the cut off. this will still roll the edge. As for the tubing cutter itself and the lathe I have had no luck, the tubing seems to twist under the strain but then agian thats my luck.
A slitting saw works great but can leave a nasty burr.
Please post any news about what works as I run into this on an ongoing interval.
John
Old 01-20-2006, 09:07 AM
2muchstuff is on a distinguished road
For my model work I use the HF mini cut-off saw to cut thin wall brass tubing. It has a small slitting saw blade on it and if you cut it quick, the burr is minimal. The table leaves a bit to be desired though. I have seen an outside deburing tool for tubing somewhere, can't remember where, that could be attached to the end of a 1/4 hp motor shaft. It would make an easy job of it.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 01-20-2006, 09:17 AM
Gold Member
The problem with deburring tools...
Some of the cut off parts are only 1/4 inch long. That makes them pretty hard to hold while deburring them.
Keep the ideas coming.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 01-20-2006, 09:38 AM
HuFlungDung's Avatar
Moderator
I think I'd try cutting off in the lathe. This makes it easier to dress the burr on the outside end of the part while it is still attached to the stock. A 5C collet chuck (or equivalent) would be necessary. I think a grooving tool (just plain flat top zero rake for brass) and a very keen edge, ground about .015" wide should cut very clean. A slow feed will help the final little 'ring' to pop off the end of the part. This end of the part will be sharp edged, but should still be straight. Then you could consider some kind of vibratory finishing or tumbling with some kind of small beads.
Old 01-20-2006, 10:06 AM
The Puma Man is on a distinguished road
I did some components like this a few years ago. They were filled with a low melting point wax wich was then placed in hot water. There was very little burr that I remember. Whether this would be cost affective in your case I'm not sure.
Old 01-20-2006, 05:44 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool Another Idea!
This may sound a bit extreem, but what if you placed a steel pin half way inside the end of the tube, hold the tube and pin in a 5C collet, and take the rolling wheel cutter from a standard tubing cutter and mount it in a holder, then feed it in till it hits the steel pin and cuts (pinches) the brass off to the desired length.
Also, a second-operation spindle that has a 5C collet would make deburring a little easier too!
Hope this helps!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 02-25-2006, 08:03 PM
Gold Member
Well, I've found that it cuts very nicely using a slitting saw. The bur is pretty small. I'm planning on cleaning it up in a vibratory finisher I just bought on ebay.
Does anyone have any suggestions on what media to use?
As a reminder: 11/32 diameter thinwall (.015) brass tubing.
Your suggestions would be appreciated.
Thanks,
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 02-25-2006, 09:11 PM
WhiteTiger is on a distinguished road
You might try doing your cutoffs on the lathe with an inside grooving tool. Always worked well for me in cutting off cartridge brass for custom chamberings. If nothing else, you avoid the whole tube collapse problem, and the burr is minimal and external where it's easy to knock back by hand.
Tiger
Old 03-27-2009, 02:58 PM
scuba840 is on a distinguished road
I found this out while watching a TV show on how they mfg musical wind instruments.
Take your thin-walled brass tube, fill it with water and freeze it. Take it from the freezer and cut it. with the ice core inside holds the dimension.
This can also be used for bending the tubing, too without collapsing the walls.
Cheers!
