Old 12-17-2005, 05:01 AM
guido's Avatar
guido is on a distinguished road
cutting forces milling
Does anyone have data or can refer to a book or website that has info on cutting forces during milling?
Guido
Old 12-17-2005, 06:43 AM
pauluk is on a distinguished road
hi
do you want the power required to remove metal at a given rate, or the forces that will be put into the job? can you post more infomation
Old 12-17-2005, 10:26 AM
guido's Avatar
Pauluk
Interested in the forces. X,Y and Z direction during milling. Want to design a mini VMC and can't find much info on this subject.
Old 12-17-2005, 12:33 PM
Ah ok,
I have formulas in a book on calculating the power required for given materials, cutters etc, but I’m not sure they would be much help. I can post them if they are any use to you. You can’t build a machine that is too ridged, but you sure can build one that is not ridged enough, build as ridged as you can
Old 12-18-2005, 05:19 AM
guido's Avatar
I have those formulas also..if you have tabels vor specific cutting forces (Kc) for different materials during milling ...then it would be great if you can post them.
Besides issues on rigidity of the frame..I also need the forces in order to correctly dimension linear guides, ballscrew, motor etc.
I think however that you can build a frame that is to rigid. Mayb more on that later..have to think about it..
Thanx
Old 12-18-2005, 09:36 AM
HuFlungDung's Avatar
Moderator
Are you planning to mill metals?
I dare say that more power is required of the axis motors to move the machine at rapid, than is required to feed during cutting. IF climb milling procedure is followed, the cutter practically feeds itself, and the servos only regulate this tendency. Of course, there will be instances where the tool must cut full diameter and this takes a bit of muscle, but suffice it to say, if you've got good rapid speed capability, you've got ample power to feed with.
Another factor to consider, is this: how large of a tool will be used, and how dull will it be permitted to get? The dullness (or even edge hone factor) could easily double or quadruple the stiffness requirements of the machine frame to keep vibration within acceptable limits.
There will always be a reaction caused by the tool edge penetrating the work. Worst case, a two flute cutter where the entire cycle of 'edge hits part, spindle and work deflect from each other, metal begins to deform, spindle and work begin to settle back towards one another, the chip completes, and the spindle and work spring free in the opposite direction, then the next edge hits'. This pattern creates the main frequency of cutting vibration (I'm conjecturing), so the real issue, is not the strength of the machine, but how fast will it dampen this vibration.
Dampening is related to material type (how well shock waves propagate through it) and mass. You simply cannot have too much mass while cutting. A heavy machine will cut quietly, while the light 'engineered one' will be ringing like a bell, and next to useless.
My 2 cents. Look at what has already been built. Notice there are no machine tools that look like tinkertoys, they look more like Stonehenge.
Old 12-18-2005, 11:12 AM
Mcgyver is on a distinguished road
who are the engineers out there? isn't the force directly tied to power? i.e. the cutting force of a .100 deep cut with a 1" end mill at .001 per tooth will be less than .200 @ .003 per tooth.
good post Huflung, someone said 'a fly landing on the tailstock will affect the bed shape', - the point is any force on the machine frame will have an effect, you need it massive such that the movement is negligible or insignificant.
I remember reading once that Porsche one year increase unibody rigidity by 50% while also achieving a weight reduction. Some seem to have the view that machine tool designers have let us down by not doing the same, or that with enough intellect and a thoughtful approach convention can be broken and tinker toy marvels will prevail.
Hopefully innovation does bring breakthroughs, but the reality is the Porsche unibody example is a silly analogy to machine tools, the forces, frequency and tolerance of movement are clearly not comparable…try to design something that is removing several cubic inches of steel per minute, with a specified work envelope and holding a tenth or so tolerance (not that we always work to a tenth but how much machine movement is acceptable?) and chances are its not going to be any lighter than what we already have, and perhaps a lot heavier depending on materials
Btw, there usually is correlation between massiveness and quality/accuracy – compare a hardinge or monarch lathe to southbend, so make it as massive as you can
Old 12-18-2005, 12:10 PM
guido's Avatar
I'm an engineer...Do not get your remark about the cutting force...
To calculate the cutting force you need to know the specific cutting force of the material...
I'm not trying to build a tinker toy marvel. I can guarantee you that cutting forces are one of the most relevant issues for commercial machine tool builders.
The goal is to engineer a light construction that is stiff at the same time. Most important is to keep the mass as low as possible near places were vibrations with a big amplitude might occur.
Old 12-18-2005, 12:20 PM
Hi All
Here are the power constants (Kp) for different materials, which you probably have anyway, but there is probably a direct comparison since the cutting forces are directly related to the power used to create the forces.
Power Constants Kp
Material Power Constant (inch units) Power Constant (metric units)
Aluminium
Cast 0.25 0.68
Rolled (Hard) 0.33 0.90
Bronze
Hard 0.91 2.48
medium 0.50 1.36
Soft 0.33 0.90
Brass
hard 0.83 2.27
medium 0.50 1.36
soft 0.25 0.68
leaded 0.30 0.82
Grey cast iron
from 0.28 0.76
to 0.91 2.48
plain carbon steel
from 0.63 1.72
to 1.14 3.11
Free machining steels
From 0.41 1.12
To 0.62 1.69
Tool steel (unhardened)
from 0.75 2.05
to 1.30 3.55
Cast steel
from 0.62 1.69
to 0.86 2.35
To echo what Mcgyver was talking about, cars, be they Porsche or any other flex in reaction to loads created by driving this is how they absorb shock loads (imagine hitting a deep pot hole at high speed). If the car was so rigid that it did not flex to any degree your high performance Porsche would probably weigh about 65 tons, have about 1200 BHP and do 40 MPH. Vehicles like this do exist, they are called tanks and they flex very little. So if you want to build a machine which takes very light cuts with a high-speed spindle at relatively low feed rates build a Porsche. If you want to take heavier cuts with bigger cutters at higher feed rates build a tank. Me i would take the tank any day.
I fear I may be talking rubbish so I’ll stop there
Old 12-18-2005, 12:49 PM
guido's Avatar
huflungdung,
Yes planning to mill metals.
At this point I tend to say that I'm not interested in rapids because I won’t use it as a high volume production machine. So my philosophy is that my machine need enough power to cut metals...and at the same time I want to keep the cost down as much as possible...meaning small motors, linear guides ball screw etc. Probably after selecting the motors based on cutting forces I will be left with acceptable rapids.
The machine will be relatively small...tool size of max 10mm D.
  #11   Ban this user!
Old 12-18-2005, 01:38 PM
guido, not that you were doing so, but in general there are a lot of threads where it seems like people harbor this notion that machine tools are as massive as they are because the engineers/designers really haven't done their jobs as well as they could. I agree with you, other than supporting its own mass, the cutting force is what is at issue, but that is only 1/2 of it - we could agree on what the cutting force is and still build radically different machines depending on what deflection is acceptable.
I'm not an engineer so you'll quickly be able to run circles around me on technical points, how ever having a 2000lb cast iron mill wanting to hop around the shop is also compelling towards the belief that big bloody cast iron pieces make for a good machine.
In theory, there should be no discrepancy. If we plugged in the forces and deflection tolerances into a model, we should get the same answer – my point is that there is no free lunch and the answer will be the type and massiveness we see on existing tools.
Re cutting forces and power, I’m not sure of this so I presented it as a question. it’s been a long time since high school physics, but isn’t the magnitude of the force relative to the power? Common sense says there is a correlation between the power, or material removal rate (the calculation of which requires a constant for each material as you mention) and the force. iirc force is a vector having both a magnitude and direction. If the magnitude either is, or is tied to the power, then what we’re missing is the direction. Unless it’s a shaper or planer, the direction is constantly changing as the cutter rotates, hence the machine must be built to take the loads in all directions. Hence the idea that the cutting forces involved depend on the power used, which depends on the material removal rate. The max material removal rate does change for materials, but at the max, won’t the power be the same?
Just to convince myself I’m only partially crazy, here’s some material I found that ties together material constants and power to calculate the force magnitude
http://www.hytec.com/Designin.pdf
Old 12-18-2005, 01:53 PM
Moderator
If you like The net effect will be the same: determine how fast you want the machine to move, and you will have lots of power left over to do the feeding. If the machine cannot rapid any faster than it feeds, you will soon put it in the dumpster
Typically, the table and workpiece have a sizable mass. You can apply your formula to determine exactly how much power it takes to accelerate this load to full rapid speed. This is the most work that the feed motors have to do.
The amount of power it takes to cut the material is readily available information, but that only applies to spindle horsepower. So you could have a 10hp spindle (if you like) chomping away on this part. That 10hp could take a good bite and the force that the spindle/tool is putting on the machine has little to do with the XYZ motor power.
Feed horsepower could be miniscule, especially if climb milling.
