Old 12-13-2005, 04:13 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Cool Modified ACME TAPS
Does anyone know where I can get a spirial point Acme 1/2-10 tap?
Are there any cutter grinder people out there who can sharpen a plug tap into a spirial point? If I had a surface grinder I would do it my self!
I've been having trouble power feeding a 1/2-10 acme plug tap into plastic, it reams the first 3 threads right out before it grabs! If I can't find a spirial point tap, then I'll have no choice but to make a tapping stand with a lead screw to feed the tap into the plastic! That's a lot more work than I had planned on! And the last thing I need is another project!
If I turn the tap with a tap handle under a center point, the tap starts fine! But it takes too much time and effort! I just ordered a two stage tap from ENCO, it may help but it is way too long for what I need! Single pointing the threads in my lathe is not a good Idea, as the lathe I have such a piece of junk! It's barely able to do simple stuff!
The fidgiting WidgitMaster!
(Never be bored again!)
Eric
ID:	12794   Click image for larger version
Old 12-13-2005, 06:10 PM
HuFlungDung's Avatar
Moderator
I doubt that a spiral point is going to self feed any better than a standard tap. Now spiral flute, that would suck itself in, but maybe too fast
Any reason you cannot power the tap with your lathe, or a drill press?
Old 12-13-2005, 07:11 PM
Gold Member
Now I had not thought of the drill press!
It has a much looser spindle than the mill, it may work just fine!
As I said, my lathe is a real waste of time, I'm currently looking for a used one which is made in America, not China!
I made the mystake of buying a Jet 9x20 lathe ....
The underside of the ways, which the saddle clamp rides on is so uneven, it is either way too loose or too tight to slide! The whole machine needs to be re-machined to make it work! Not my idea of a fun or profitable project!
Thanks for the insight!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
