I've been using Kool mist coolant for a few months, but I am starting to run out so I need to look around for some more coolant. Kool mist works fine, but I like to try new things. While searching the ENco website, their generic coolant is pretty much half the price of the other stuff for a 1 gallon container. Does it work well?
THis coolant will be used for a milling flood system, primarily aluminum as material. Also for all lathe operations, mostly aluminum as a material, but some mild steel too.
I use Kool mist here at home, and Rustlick at school, and have found they both work well. So I am under the impression that this stuff will work fine too, but it never hurts to check
