Results 1 to 7 of 7
Thread: Mill Scale Removal
    Nov 2010
    Mill Scale Removal
    I have a large sign ( 4' x 16' ) made of steel and I need to find some better way to take off mill scale. I usually do my small pieces in a muratic acid bath, however this project is too big. Any suggestions would be appreciated.
    Tony
    May 2004
    Depends on what finish you want when you are done. Sand blast. Needle de-scaler. Grinder/sander.
    http://www.kirkcon.com/
    Nov 2010
    Thanks for the reply. I can't sandblast and grinding is going to be a long processs. What is the needle de-scaler.
    Tony
    Feb 2012
    A needle decaler will take you forever.
    Gey yourself a 7 or 9 inch grinder, fit it with a sanding disk, a pack of spare sanding disks... and a cold six pack of sodas.
    Try to work in the shade and set aside 1-2 hours depending on how bad the scale is.
    It's just work. You don't mind, it don't matter.
    Apr 2007
    That is a big sign. If you can get it to a position where acid fumes are not a problem, then in theory you can use a pump and recirculate the acid over it using a hose and pump. That is easier said than done.
    There are some products like naval jelly that will convert the rust to a more stable compound, but it depends on the condition of the surface. It is more for light rust than heavy scale.
    There are some sandblaster setups that will catch the dust while you work if that is the issue. Perhaps make a box that fits over a section of the sign at a time if you want to DIY.
    Sep 2012
    india
    Question online mill scale removal
    we are in process of putting up new wire rod mill.
    and
    i just need help about how to remove mill scale online in rolling mills....????
    any suggestion would be appreciated.
    kush
    Mar 2006
    kush, "google" pickled and oiled.
    Dick Z
    DZASTR
    1. Need Help!- Mill Scale
      By TonyWish in forum Plasma, EDM and other similar machine Project Log
      Last Post: 07-04-2012, 12:12 PM
    2. Problem- Eldorado Bridgemill mill head removal
      By leeharrysouth in forum Shopmaster/Shoptask
      Last Post: 03-18-2010, 05:02 PM
    3. Mill Table Removal
      By elnerdo in forum Tree
      Last Post: 09-14-2008, 04:47 PM
    4. Mill Scale
      By Alex2005 in forum Linear and Rotary Motion
      Last Post: 08-06-2007, 04:59 AM
    5. Quill Scale for Knee Mill
      By TZ250 in forum Knee Vertical Mills
      Last Post: 11-24-2006, 06:59 AM
