Results 1 to 12 of 12
Thread: SFM 17-4 Stainless Steel
    Apr 2012
    Smile SFM 17-4 Stainless Steel
    Any info on SFM for a carbide slitting saw operation of 17-4 stainless, dry machining? I'm using a 36 tooth, .0225" thick, 3" diameter saw blade, making .031" deep slots into orthodontic pieces. Lining up 20 parts in a fixture to machine a row is about 3 1/2" long. Thanks.
    May 2004
    What did Machinery's Handbook recommend for SFM of carbide on 17-4 stainless?
    http://www.kirkcon.com/
    Apr 2012
    I Don't know. Don't have access to the machinery handbook.
    May 2004
    I do not have time to look it up for you. I would guess will be about 85 SFM. But you should verify before continuing.
    Registered BobWarfield's Avatar
    May 2005
    G-Wizard suggests 229 rpm, 10.52 IPM for that cut.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Apr 2012
    Thanks a ton. Good info. I'll let you know how it goes.
    Apr 2012
    Would you guys climb cut with a slitting saw for these parts? I know its a given with regular end mill machining operations.
    May 2004
    I almost always climb mill for finish cutting. But it also depends on your set up and part geometry too. Will climb mill pull the part out of the work holding or not.
    Apr 2012
    I don't think my parts will fly out of my machine fixture. It holds them nice and tight. On top of that, I've got a new fixture deisgn coming the next couple weeks that has a few more features which should hold the part even more rigid. I want to give the climb cut approach a try. I hope it can really help out my tool life, and reduce the cutting forces on the leading edges of the saws teeth. I'm curious if it will eliminate some burrs also.
    May 2011
    I climb cut about 99% of the time and would highly recommend it for a slitting saw. 100 SFM (127 RPM) sounds about right for cutting dry and about 3.6 IPM on your feed (.0008"/tooth).
    Jul 2008
    united states
    I used to climb on slitting, until I was reading a thread on this site. And everyone stating that conventional was the way to go. Im confused
    Apr 2012
    Hey dfearnow,
    Was there a big difference when you switched from climb to conventional? Part quality, tool life, part hold down?
    1. Stainless or non stainless steel ACME screws?
      By amanmazleigh in forum Linear and Rotary Motion
      Last Post: 07-07-2011, 12:00 AM
    2. Stainless Steel
      By waterfxmatt in forum Hypertherm Plasma
      Last Post: 07-29-2010, 06:59 AM
    3. Need Help!- Stainless Steel
      By waterfxmatt in forum DynaTorch
      Last Post: 02-09-2010, 02:00 PM
    4. 303 vs. 304 stainless steel
      By pearldiver in forum General Metalwork Discussion
      Last Post: 11-28-2009, 08:12 PM
    5. Steel or Stainless
      By tool_man in forum Casting Metals
      Last Post: 10-29-2006, 06:46 AM
