Results 1 to 7 of 7
Thread: Flat and Cheap?
    Apr 2012
    Flat and Cheap?
    There didn't seem to be a best place to ask this, here is the best alternative. I'm working on a project that would benefit from a support of as near perfect flatness as possible, as inexpensively as possible. Material itself is actually not that important, it's a light weight low force application and it's best to think of it just as a table surface to place a light weight object on. The area would be, again, not critical, but about 7" x 7" ideally. If you have minimal design constraints and wanted a super flat registration surface for the lowest cost, what would you chose? Preference would be lighter over heavier, thinner over thicker if anything. I don't mean to sound outrageously vague, just hoping to help think outside the box.
    Jul 2005
    Get the self-levelling floor topping compound that The Home Depot has. Make a frame out of wood and plywood, a good strong, stiff frame, maybe a torsion box style, with a rim around about 1" high and pour the topping compound mix into this.
    May 2004
    How flat is flat? MIC-6 aluminum plate?
    http://www.kirkcon.com/
    Apr 2012
    Geof, were one to measure the flatness of such a surface, what do you think it'd be over that distance, discounting for meniscus at the edges? An optimal spec would be say +/- .oo3", in that realm?
    @txcncman, that would be flat for this use.
    Jul 2004
    Plate glass is fairly flat and may suit your needs if you don't need to drill into it. I did a quick search and there seems to be plenty of posts about glass flatness on various machining and telescope forums.
    -Matt
    Feb 2009
    Go to home depot and buy a 8x8 tile of granite. Not too heavy, and is cheap and flat. You can drill in it with masonry bits if you needed to.
    Jul 2005
    Actually I read your size too quickly and got 7 feet by 7 feet so my suggestion is not really applicable.
    1. Lathe Bed: how flat is flat enough?
      By Donkey Hotey in forum Haas Lathes
      Last Post: 05-17-2010, 03:35 PM
    2. Cheap HF router bits, just plain cheap?
      By sonicwonder2000 in forum DIY CNC Router Table Machines
      Last Post: 09-03-2009, 10:18 PM
    3. 100% flat table for flat bed lamination
      By Bernhardsen in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 08-24-2008, 09:31 AM
    4. Replies: 7
      Last Post: 08-16-2007, 01:26 PM
