Results 1 to 5 of 5
Thread: Making serrated teeth on metallic surface
    Registered fredi's Avatar
    Mar 2012
    China
    Dear All
    I need to find a way to make the serrations on the metallic surface similar to the attached. Pls clarify the procedure and machines.
    Fredi
    Attached Thumbnails Attached Thumbnails Making serrated teeth on metallic surface-sample.jpg
    May 2004
    In the part pictured, it is fairly easy. Use a 90 degree tool, such as an engraving tool. Machine 45 degree lines at the needed pitch distance apart, at a depth that will result in the amount of pointing of the teeth desired. Measure from root to root or crest to crest to obtain the pitch distance.
    http://www.kirkcon.com/
    Mar 2006
    There are serration milling cutters similar in appearance to gear hob cutters. I used them in the past to serrate the teeth in the face of sealing dies for packaging machines.
    Dick Z
    Add: I "googled" serration cutters. There are many Chinese and Indian suppliers listed.
    DZASTR
    Registered beege's Avatar
    Feb 2008
    A shaper and a knurling tool
    Mar 2012
    China
    Smile
    Quote Originally Posted by beege View Post
    Thank you beege for your effective reply.
    Would you pls clarify the rule of the knurling tool for my surface. I have never seen any knurling tool for flat surface upto now. Do you have any link about them?
    1. Need Help!- making surface into solid
      By sawdustman18 in forum BobCad-Cam
      Last Post: 03-15-2012, 11:44 AM
    2. Replies: 7
      Last Post: 10-31-2011, 02:20 AM
    3. Traditional Making of Granite Surface Plates?
      By applebuilder in forum Glass, Plastic and Stone
      Last Post: 07-20-2011, 02:21 PM
    4. Making a curved surface
      By Megaplow in forum SolidCam
      Last Post: 07-18-2011, 10:52 PM
