Results 1 to 3 of 3
Thread: Multiple diameter step drilled hole.
    Oct 2005
    Question Multiple diameter step drilled hole.
    Hello All,
    I have a job with multiple diameter step drilled holes. The material is 316L SST, there are 3 different diameter holes at the same position... Hole 1 is a .3125 diameter 6.71 deep, hole 2 is a .500 diameter 4.75 deep and hole 3 is a .625 diameter 2.75 deep... We are going to use coolant thru carbide drills in a Mori Horizontal... My question is, in what order I should drill these holes (big to small or small to big)? Any feed back would be appreciated...
    Jul 2005
    Big to small; carbide drills should always cut along the full length of the cutting edge.
    May 2004
    Quote Originally Posted by Geof View Post
    +1 - Largest diameter first.
    http://www.kirkcon.com/
  1. runout on drilled and reamed hole in lathe
    By photomankc in forum Benchtop Machines
    Last Post: 06-28-2012, 01:21 PM
  2. advise reaming A2 .250 deep hole .432 diameter
    By Hiredgun in forum General Metal Working Machines
    Last Post: 12-20-2011, 09:29 PM
  3. Newbie- V21 help with drawing a drilled hole at 10 degrees angle
    By Billyisgr8 in forum BobCad-Cam
    Last Post: 04-07-2011, 02:26 PM
  4. Fastest Hole drilled yet
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 02-28-2011, 05:53 PM
  5. Replies: 14
    Last Post: 10-23-2007, 07:41 PM
