Results 1 to 7 of 7
Thread: ally melts when machining
    Jan 2011
    uk
    can anyone help.
    i have done a design for a radiator cover for my motorbike cut it out on my cnc machine on a piece of ply to check everything was ok.
    then tried machining the design on some 1050 sheet alluminium using a 6mm twin flute end mill. im using a routeron my machine set to the lowest speed
    and a feed rate of 3mm a second but the ally is melting quiet a bit while cutting.
    two thoughts either i am cutting to fast or the ally is to soft to be machined.
    has any one had experience machining this type of ally.
    Registered Bob La Londe's Avatar
    Oct 2008
    I am not familiar with 1050 sheet, but I do 3d work in 6061 regularly. This is what I have found works.
    Higher RPM
    Feed to match
    SHARP! Cutters. For a finish quality job I'll often start with a brand new cutter each time.
    Flood coolant. (for small jobs I can get away with either hand spotting with Wd-40 or sometimes just a continuous air blast) I prefer flood coolant.
    The largest cutter that will fit in the job
    Bob La Londe
    http://www.YumaBassMan.com
    Jul 2005
    1050 is almost pure aluminum and has very poor machining properties. If you have a really sharp cutter running fast using a low feed and good lubrication you might be able to machine it. Your best approach could be to get a different alloy. If the cover is only machined and does not need to be bent 6061 would be the best.
    Oct 2008
    Quote Originally Posted by Geof View Post
    7075 machines nicely to, but is hard to weld. Its strong, but have no idea how it brakes (bends) though.
    Bob La Londe
    Registered riche543's Avatar
    Oct 2011
    Subscribed
    Thanks for this info also had trouble cutting 1050 when the ally guy said it was 6061. Is there anyway of telling what grade it is so you don't have too take aluminum shops word for it?
    Cheers
    Riche
    Oct 2008
    Ask to see a copy of the mill certifications. Doesn't work if you are picking though the drops. Most bigger pieces are printed from the mill. Just about all the 6061 I buy says 6061 right on it. If you feel your problem is just a case of the metal guy selling you what he has instead of what you want you might want to find another metal guy. I do a lot of business over Ebay with either the 6061dude (2nd choice) or StockCarSteel (1st choice) for the smaller pieces of 6061 I use in mold making. They have both been very good at providing exactly what they say they are providing and StockCarSteel has been know to go the little extra for me.
    Bob La Londe
    Jun 2011
    bavaria
    A simple but not very precise method is to put a drop of sodium hydroxide to the surface. If it colors black, it should be good to machining, cos it have copper or zinc in the alloy.
    If white, than its better for bending, but not for milling.
    1. Jinan Quick Fulltec CNC Machining Center Ally
      By Ally in forum Chinese Machines
      Last Post: 03-20-2012, 02:43 AM
    2. How to use Flux in aluminum melts
      By banctecbobn in forum Casting Metals
      Last Post: 05-26-2010, 03:00 PM
    3. Cant machine Ally :(
      By stk2008 in forum DIY CNC Router Table Machines
      Last Post: 05-16-2010, 11:32 AM
    4. Homemade CNC - Plexiglas melts whereas Perspex cuts fine?
      By HankMcSpank in forum Glass, Plastic and Stone
      Last Post: 09-17-2009, 08:17 AM
    5. Plastic Melts Onto Endmill
      By DroopyPawn in forum Glass, Plastic and Stone
      Last Post: 11-12-2007, 05:51 AM
