Old 11-18-2005, 01:04 AM
Chad Cappa is on a distinguished road
HELP - How to service a hydraulic vice.
I have a 2 ton hydraulic vice that has slowly been leaking oil over a number of months. Does anyone know how to service or add oil to these vices? It has two large grub screws in the end of the moving jaw, I think hydraulic fluid goes into one and is bled out the other but I am not sure.
Any information would be greatly appreciated.
Cheers!
Old 11-18-2005, 10:32 AM
ISO Coder is on a distinguished road
What type of vices do you have, is it with a crank and hydraulic power booster or with hydraulic pump ? Who made your vices ? I have experience with Allmatic and Fresmak vices,if it one of those maybe i can find some partslists for you.
Old 11-18-2005, 11:01 PM
It is Matohling brand and has a crank with hydraulic boost.
Old 11-19-2005, 01:03 PM
I do not know that brand, but the Fresmak vices work like this (simplified).
When the jaw reaches the workpeace a small piston starts compressing the oil in
a chamber that presses on a bigger piston that moves a rod that goes through the spindle, its most likely that one of the seals around the pistons are leaking and need to be replaced. If you´re lucky your vice uses standard seals, but i woldnt bet on it.
It shouldnt be too hard to do the repairs yourself.
I woluld try to find a reseller that carries spareparts and perhaps can help you with a speareparts list.
Old 11-20-2005, 09:12 AM
I really dont want to go pulling it apart, just want to re-oil it somehow. But thanks for all your help and information. At least I have a better understanding of how they operate. Cheers.
