Results 1 to 5 of 5
Thread: Newbie here...Parameters of Drilling of Stainless Steel 304
    Oct 2011
    Malaysia
    Hey guys!
    I am new to my job and I need to conduct a drilling on a stainless steel 304 plate on my work. But I know that austenitic stainless steel is not an easy material to deal with, so I am looking for a suitable drilling parameters to do this before I break the drill bit
    So, here are the information of the tool and workpiece:
    Drill bit : ATI Garryson tungsten-carbide drill
    No. of flute: 2-flute
    Diameter : 5mm
    Workpiece : Stainless Steel 304
    Workpiece thickness: 6mm
    Hole type : Thru hole
    So may I know the optimum drilling parameters for this situation? What is the cutting speed and feed rate should I choose?
    Your help is highly appreciated. My supervisor require me to complete the drilling as soon as possible...
    Registered fizzissist's Avatar
    Apr 2006
    Don't see any ATI "Garryson" drills, only Stellram...
    A good place to start would be around 250SFM, and a feed of about .004"/rev.
    ....or a ballpark of 4500rpm, and 10ipm feed.
    Mar 2012
    U.S.
    250 Sfm might be a little fast especially if you are looking for good tool life i would say 100-150 sfm with .003 chip load so say you are 125 sfm that would be 2424 rpm and 14.5 ipm
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    Better is to use HSCO drill..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Oct 2011
    Malaysia
    Thanks for the input guys. Well since I am new to this so I am going to do it in a conservative way to prevent massive heat generation and tool breakage, so is it safe to drill with 800, 900, and 1000rpm and feed rate of around 3.94ipm? I am new to this and my concept might be wrong.
    Thank you.
    1. Stainless or non stainless steel ACME screws?
      By amanmazleigh in forum Linear and Rotary Motion
      Last Post: 07-07-2011, 12:00 AM
    2. Need Help!- DRILLING 17-4 Stainless Steel
      By Ed MacPherson in forum General Metalwork Discussion
      Last Post: 05-21-2011, 06:58 PM
    3. Need Help!- Drilling 321 Stainless Steel
      By quick_stickz in forum General Metalwork Discussion
      Last Post: 05-21-2011, 06:55 PM
    4. Drilling Stainless Steel
      By foil25 in forum Mechanical Calculations/Engineering Design
      Last Post: 06-25-2008, 09:30 PM
    5. Seeking Drilling Parameters for Stainless Steel 401
      By hallowed in forum General Metalwork Discussion
      Last Post: 09-30-2007, 04:34 AM
