Originally Posted by
bebob1
If I have threaded rods that I want to turn the ends of for bearing support, how do I go about doing this on the lathe while maintaining perfect rotational axis is centered and true?
I have soft jaw chucks as well as independent jaw chucks for the work.
Im wondering about the workholding part. How do I grip the threaded rod? How do I indicator it in? How do I ensure the axis of rotation remains in the center of the rod? Indicatoring will be much more difficult than on round stock since the threads are helical and your indicator stays in the same place and goes over valleys as you rotate the workpiece.
Maybe turn it down until it is round and then measure offsets and readjust and turn again?
Or hold a large piece, drill it, then tap it on the lathe chuck, then thread the rod right in to hold it? But it probably wont hold very still so then superglue it in place?
WHats your strategy for this?
