Old 11-15-2005, 04:34 PM
MBG MBG is offline
MBG is on a distinguished road
End mill sizes
I need to cut a .020" slot. Is there and endmill that would cut this? Peferably carbide. I want to do it on an indexing head. and spinning the part at the same time therefor getting a grove around the diameter.
Who thinks this would work? Currently I lathe turn it but don't want to do that anymore.
Old 11-15-2005, 04:46 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
You can get endmills as small as .005", so the answer is yes.
Pay close attention to speeds and feeds - a .020" endmill is gonna snap faster than Mike Tyson at a cheerleader convention.
You might be better off in the lathe with a grooving insert ground with adequate side and end clearance.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 11-15-2005, 04:49 PM
psychomill is on a distinguished road
Yes you can get a .020 carb endmill (and even smaller). Check Robb Jack or even Micro 100. There are many others as well.
Will it work?... Yes, but why would you want to? A groove like that is much faster to run on a lathe, consistent, longer tool life, etc.... I'd think you'd be happier with parts on the lathe than milling it.
It's just a part..... cutter still goes round and round....
Old 11-15-2005, 04:52 PM
MBG MBG is offline
true but my lathe is manual.. You do 2k a week on a manual mill!!! it is ridiculous. If I can put it in the mill I would be happier than a pig in **** .....
What to do waht do to...
Old 11-15-2005, 05:00 PM
mxtras's Avatar
Silver Member
I love running manual lathes....what's the aversion to a manual lathe to cut a face groove?
From what you describe, the lathe is the way to go.
Scott
Old 11-15-2005, 05:33 PM
Yes, but I think a big reason why you CAN do 2k a week is because its on a lathe. Put it on a mill, you may not make as many,... certainly not as quickly at any rate.
What is the reason (besides the quantity) its a pain on the lathe?
Old 11-15-2005, 05:47 PM
JPMach's Avatar
JPMach is on a distinguished road
Sounds like it's time to get a cnc lathe!
JP
Old 11-15-2005, 06:04 PM
MBG MBG is offline
JP
true... but if I got a mill I could do A LOT more work... That is my catch 22.
Old 11-15-2005, 06:06 PM
MBG MBG is offline
just time and exhaustion. Really it isn't time it's just tiring and I bet if all I had to do was load and press a button I wouldn't be as tired.
Old 11-15-2005, 07:33 PM
HuFlungDung's Avatar
Moderator
If the configuration of the part is suitable, you might use a slitting saw to cut the groove in the mill. I'm not saying it is the wise thing to do, but if you are determined..... I would not waste 2 seconds considering an endmill for this type of job.
  #11   Ban this user!
Old 11-15-2005, 07:47 PM
MBG MBG is offline
no? Well the thing is.. I only have money for one type of machine right now... I got this job to do for 2k a week at $.75 soo if I can do it decent money.. but I want to have a mill cause I can do a lot of other jobs with it also.... :\ I dont know.. It is just a groove
why wouldn't you use an end mill?
  #12   Ban this user!
Old 11-15-2005, 07:49 PM
I'm with Hu on this one. If you're 'determined' to mill it, I'd go with a saw.
Yes, if you got a mill you could do a lot more work (at least a lot more different type of work). However, cutting a groove on the OD of something that can be held in lathe is not exactly the right direction in my mind (unless you only had a mill and not a lathe). Time is money. Besides, what makes you think that loading 2k parts on a mill to cut a groove is less exhausting than loading 2k parts on a lathe? Not to mention, for this app., the lathe is 10x easier to set up and get going....
