Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: machinning aluminum plate(s) techniques
  1. #13
    Jul 2007
    I have an aluminum spoil board/t-slot table.
    To save my table, I place my parts on top of "plumbing" tape. I don't have the stuff near me to give an exact name, but It's this rubber tape I found at home depot/lowes. It has a nylon type back to it. It doesn't stick to anything unless it's under pressure. It's about a 1/32 thick and fairly cheap.
    I place a piece of it under each of my bolt downs of my material and also place strips down to help support my material. This saves my aluminum spoil board, keeps my part from slipping to much and I can also set my cut values to cut beyond my material to help get clean cuts and of course through cuts.
    Carpet tape is usable, harbor freight sells it the cheapest. About a $1.00 a roll when you can get it. It's been a while since I've bought the stuff, 6 rolls have lasted me awhile, but I rarely use it unless I'm doing small parts on aluminum when I need CLEAN cuts.
    If you are cutting this aluminum and it's rattling, something isn't working well for you. My stuff doesn't rattle but I also use .25 & .125 inch bits.
  2. #14
    Apr 2007
    We use a vacuum plate for parts that are 1/4" thick and under. These are not the expensive ones requiring a vacuum pump. It runs on compressed air creating a venturi effect. You use a bigger aluminum plate with grids milled into it, and use o-ring material around contour of part. I was amazed at how well it held several different work pieces.
  3. #15
    Registered Bob La Londe's Avatar
    Oct 2008
    Quote Originally Posted by firecat69 View Post
    I'll probably have to buy a commercial one someday and study it. I tried a home made venturi plate and for a small part (1" x 3") I was not thrilled. I do have an idea for improving it though. To many projects not enough time.
    Bob La Londe
    http://www.YumaBassMan.com
  1. RFQ: 1/4 x 14 x 3 aluminum plate
    By Tallen in forum RFQ (Request for Quote)
    Last Post: 04-24-2011, 02:38 PM
  2. CNC Machinning parts that are too big for the CNC range??
    By zaebis in forum Benchtop Machines
    Last Post: 04-29-2009, 09:22 AM
  3. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 01:48 AM
  4. Where do you get your aluminum plate
    By Cold Fusion in forum General Metalwork Discussion
    Last Post: 01-27-2006, 01:37 PM
  5. RFQ - Aluminum plate and spacers
    By tjstraz in forum Employment Opportunity
    Last Post: 01-26-2005, 09:25 PM
