Results 1 to 2 of 2
Thread: Slitting Saw on CNC VMC
    Feb 2012
    India
    Exclamation Slitting Saw on CNC VMC
    We have to slit around 18 slots of 2mm width on an Aluminium block with a depth of 16mm on 3 sides of the block. This is for a heat sink. We are planning to complete this in a single setting using a 80mm dia HSS slitting saw attached to our VMC spindle at right angle and run the saw on all the 3 sides.
    My questions are related to spindle speed, feed and the depth of cut that I need to provide for the slitting saw. Also, I need to know how to program this using CAM software. Any help or inputs on these questions will be very useful.
    Thanks in advance!
    Prasad
    Registered BobWarfield's Avatar
    May 2005
    Prasad, G-Wizard will figure feeds and speeds for slitting saws. Check it out.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  1. Need Help!- slitting saw on v23
    By skippyfix in forum BobCad-Cam
    Last Post: 11-09-2010, 03:32 AM
  2. Programming a Slitting Saw
    By behindpropeller in forum Haas Mills
    Last Post: 06-10-2009, 05:53 PM
  3. Programming a slitting saw
    By Dr Honda in forum FeatureCAM CAD/CAM
    Last Post: 01-06-2009, 10:35 PM
  4. Slitting Saw help!!
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 10-09-2008, 02:10 PM
  5. Help with slitting saw
    By evena4 in forum General Metalwork Discussion
    Last Post: 08-23-2008, 02:09 PM
