Results 1 to 5 of 5
Thread: trouble with chamfers in master cam x4
    Registered dcutler35's Avatar
    Jan 2012
    Unted States
    I am haveing trouble putting a 45 degree chamfer edge on a outside perimeter of a part it is a large bevel and i can do it with a 90 degree tool but i would prefer to use a chamfering tool that is 45 degrees and step it out but when i select the chamfer tool it cuts the chamfer small the tool is drawn correctly. I put a 45 degree line in my 2d drawing and did a backplot and then i put a negative value in the cut paramers to make it come out but is there an easier way ?
    Registered fizzissist's Avatar
    Apr 2006
    You know you can draw up your own chamfer tool and save it to your tool library?
    The tutorials will show you how to draw it up and save it. Since it's designed around the actual tool, you can then specify the minor and major diameters and the angle, so when you pull up the chamfer option, everything falls into place.
    Jan 2012
    Unted States
    i am using auto profile in the tool definitions and i have entered the right data. The problem is after I select an entity to start a bevel it stays away from where the bevel ought to be ? I snap a 45 degree line where I can see it in the front view and then in my cut parameters i kept putting a minus value until the tool in backplot line up with that line but there has to be a better way.
    May 2004
    Try this:
    Attached Files Attached Files
    http://www.kirkcon.com/
    Jan 2012
    Unted States
    I like how you made it a skin and then used the chamfer tool it is probable the most acurate way of doing it i was doing it without surface by drawing the radius that the bevel started and then using a chamfer tool and 2d and puttting a 45 degree wall and then going by depth
    1. 5 axis chamfers and dovetails
      By gwb in forum Mastercam
      Last Post: 02-03-2012, 03:29 AM
    2. Need an assist on chamfers...
      By gogego in forum G-Code Programing
      Last Post: 08-06-2011, 02:39 AM
    3. Newbie- Mastermcam x4 and chamfers
      By musicmaneman1 in forum Mastercam
      Last Post: 06-14-2011, 08:22 AM
    4. Need Help!- Master PCB Trouble 6MB Control
      By dialog_11 in forum Fanuc
      Last Post: 02-10-2010, 05:35 PM
    5. Need some trouble shooting advise. (Master 5)
      By Beezer in forum Mach Software (ArtSoft software)
      Last Post: 05-30-2004, 04:51 PM
