Thats actually a rather large size hole. We have them down to .05mm.
Here is a handy chart
Drill Chart
I have a cheapo MakerBot 3D printer. It's essentially a 3D CNC hot glue gun. There's a heated brass nozzle with a 0.4mm hole. How do they make such a small hole? There's no way a drill bit could be that small or am I wrong?
Here is the nozzle:
MakerBot® MK7 .4mm Nozzle - MakerBot Industries
They want 20 bucks for the nozzle. Seems expensive.
thx
Drill Chart
.4mm is a piece of cake. In brass? It's almost cheating.
Run it as fast as you can, good air blast, in a sensitive drill chuck.
Easy.
yep , i have done it several times before and for the same purpose
0.3mm , but i used a lathe
very easy
You just need a smaller chuck. A hand feed chuck is ideal for small stuff.
A pin vise isn't designed to run concentric. If it does, you're lucky.
If it don't, your hole size is whatever it ends up being along with the bellmouth you get as an extra, along with the potential for breaking the drill.
You're right, $20 is outrageous. You should make one yourself, and keep track of the hours you spend on it..allowing yourself a minimum wage rate.
Let us know how long it takes.
Buy a brass "carburettor jet" available in many very small sizes, for a couple of bucks.
That is already a screw-in brass orifice. Then you might have to turn a bit off its face on the lathe (as most have a countersunk top to the hole).
My trick with holding small drills is to get a strip of thin paper, wet my fingers and wrap it around the drill in a rolling action, much the same as a women magically threads a needle.
When enough paper, even doubling the drill diameter or more I rip off the end, stuff it in the chuck and tighten it.
Real easy with a bit of practice. Been doin' it that way for 40 years.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
I was also thinking of turning a brass shoulder bolt and then drilling a center hole ($2.50 from McMaster-Carr). I just found another place that sells a slightly different nozzle for $10.
MakerGear.com - Nozzles
The site says it's made on "high end Swiss CNC equipment"
