Results 1 to 6 of 6
Thread: Machining Titamium
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    Machining Titamium
    Haven't machined Ti in a long long time. Anyone care to give me some speeds and feeds on a lathe for Facing and OD turning then a Top notch .062 Grooving tool?
    would much appreciate it!
    6AL-4V Titanium
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Aug 2008
    titanium
    web sites
    turning
    timeout
    .milling
    timeout
    .more info
    Titanium Alloy Ti 6Al-4V
    Jun 2010
    re Ti
    Ti alloy machines very nicely IF done correctly. Beautiful finish possible. Whereas you might go flat out for plastics and aluminium, you need to go very differently for Ti. The big danger with Ti is getting it hot and/or work-hardening it.
    So you need to cut more slowly but more aggressively. Also keeping the cutter cool (cold) with either coolant or air blast (with or without mist) is essential. Do NOT let the cutter idle along doing very little: the friction will really stuff things up.
    I have used both HSS-Co and carbide. Both need to be sharp!
    Cheers
    Jan 2005
    Hey DMF those timeout links don't work correctly can you tell me where to look on that sight? I am muddling through their sight but its a lot of info.
    Thanks RCaffin but I was hoping more for numbers as I have machined it before but don't have those numbers anymore, so I'm not looking for advice just a starting point so as to shortcut the process of burning **** up.
    thanks
    Michael T.
    Jun 2010
    Ti feed & spin
    Quote Originally Posted by miljnor View Post
    I forget!
    Looking through my old files I found the following: Mach3, metric settings, Ti sheet, 4 mm carbide cutter, feed of 20 and spin of 1500 rpm.
    The feedrate of 20 mm/min is, I THINK, quite a bit too low. I think I was overiding it upwards. Just not too sure how far upwards.
    Look up surface feet/min tables to get a better idea.
    The problem with carbide cutters is that the optimal rate is just short of breaking them! :-)
    BUT: Keep the chips clear (no bumps) and keep it cool!
    Cheers
    Aug 2008
    web site
    down the page to where it has machinabilty table 1 and 2 links
    i attached table 1 on turning
    1. Job Opening Machining Fixture Designer w/machining background - MI
      By MachiningJobs in forum Employment Opportunity
      Last Post: 04-04-2011, 05:53 PM
    2. Custom Machining, OEM Machining.
      By peovo-com in forum CNCzone Site News and Contests
      Last Post: 09-02-2010, 05:22 AM
    3. MIS CNC Machining and tooling - General machining - Thermoform Molds
      By modernprecision in forum Employment Opportunity
      Last Post: 11-23-2007, 11:05 PM
    4. Machining anodized parts or anodize after machining?
      By SRT Mike in forum General Metalwork Discussion
      Last Post: 03-12-2006, 12:22 AM
    5. Machining Help!
      By Al_The_Man in forum General Metalwork Discussion
      Last Post: 11-12-2005, 04:15 PM
