Tool tip air blow
i am fly cutting some a36 steel. i am having some problems where i guess the chips are not clearing properly, perhaps stuck to the cutting tool intermittently, so it ends up scratching the surface and thus makes these random circles over my surface.
its really annoying
how do I fix the problem? I dont have flood coolant system. I also tried to remove less material and cut at higher rpm so it shoots the chips further when possible, but there will always be this random occurrence once in a while where the chip maybe sticks to the cutting edge, follows the rotation and cuts into the steel piece. this essentially leaves random circles on my otherwise flat surface.
whats solution to fixing this?
Tool tip air blow
Use a carbide insert, of the correct grade and geometry for the A36, and run it fast and dry with lots of air. You need to get that chip even hotter.
Make sure cutter dia engagement isn't more than about 75% of dia, and you're climb cutting.
