There are pro's and cons to both the synthetic as well as the water soluble oil type. with aluminum it is mostly about flushing chips so I stick with the synthetic, stays real clean, does a good job, if I need more lube I mix it a bit stronger. I think the water soluble oil may do a better job of lubricating but it can get real nasty, may last longer since only the water evaporates so all you have to do is add some water to replenish.
I have been very pleased with the "Universal" brand synthetic lube/coolant.
Sorry, lost the link to it, need to get some my self.
Ken
LinkBack URL
About LinkBacks
(..but if that is what's required, I will do so!)
