I would be generally interested as well, as I have not had much luck single point threading in 304. Too little cut and you run the risk of work hardening, too hard a cut and your tool point chips.
I will say one thing though, your passes typically should be of a gradually decreasing depth of cut until you reach your desired finish diameter. That goes for any material as far as I am concerned.
LinkBack URL
About LinkBacks
