Results 1 to 2 of 2
Thread: Cnc end mill milling question
    Oct 2011
    I have a VM-10(Hurco).
    I'm trying to speed up my cutting time on a project.
    Cutting 1018 (1.25sq - .025 thk)stock
    I'm removing all material in the X-axis holding the material on the thickness.
    I need to leave .26 out of the 1.25.
    And it has to be .610 deep cut out.
    I'm currently using 1.25 (6 flute) end mill. Taking all material out at once.
    RPM 381
    Feed 1.5
    Surface speed 125
    It takes the program 1min 8sec to complete.
    I have 230 to run total.
    What would be the fastest way to remove that amount of material?
    Please help!!
    Jul 2005
    With a coated cutter you could run at 400 t0 600 fpm which is 4000 to 6000 rpm. Even if you where taking a modest chipload of 0.001" per tooth this means your feed can be 24 to 36 ipm. This would be running dry with an airblast.
    Have a look at this thread: http://www.cnczone.com/forums/haas_m...B_you_can.html
  1. ready first cnc mill project - question on 2d cnc milling
    By bseibenick in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-31-2008, 03:27 PM
  2. Milling question
    By bjinatj in forum General Metal Working Machines
    Last Post: 03-03-2007, 10:15 AM
  3. Replies: 7
    Last Post: 01-21-2007, 08:56 PM
