Originally Posted by
sandrewb
Im having an issue getting the G84 cycle to work with a 1/8 npt tap. The threads are getting chewed up. At the moment using S225 and F.940 going 10mm deep. Any help would be super. Have kinda read that maybe pecking the tap might work best. Haven't tried that yet.
Ok ridged tapping.
G84 and G84.1
I don't have the ability to use ether one on my machine , because the controller or the machine does not have the ability to do them.
I have come up with a fix to ridged tap using just a liner move at a rpm and feed .
Stop and reverse at a different rate for incinerated speed.
so assuming the metric and imperial units are not getting confused.
I will strictly use English.
Code:
G20
M6 T1
G0 G90 H1 Z0
M19
G01 G90 S225 M3 Z-.3937 F8.333 G4 P100
G01 G90 S225 M4 G1 Z0 F8.333 G4 P100
G0 G90 H0 Z0
M30
Notice: I am using G4 as a pause , you could use G9 for a position check.
I suggest using a floating; "Z floating", tool holder for the tap.
