Results 1 to 10 of 10
Thread: This One is for MythBusters
    Aug 2006
    Yesterday our wiring guy told me a story. He claims that onion juice is the best cutting fluid for stainless steel. He says an old farmer recommended it to him and it works great. He was using a 2.5" piloted hole saw on .25" thick 303. First using a little WD40. The pilot drill made it through but when the saw touched down it ran the teeth off it in less then 1/16" depth. He got a new hole saw and drilled through an onion and squeezed some juice on the part and cut through the plate with ease. I googled it and found only one reference to lard and onion sandwich used for cutting fluid.
    Anyone ever heard of using onion juice or lard or both for such a purpose?
    May 2004
    Never heard of it. But considering the cost of onions and how much juice they actually contain, I am not about to switch.
    http://www.kirkcon.com/
    Jul 2005
    My shop has 18 machines with 80 gallon coolant tanks.....I would need an entire onion farm.
    I have heard of using lard for tapping but squished onion for a hole saw is new to me.
    Registered bobsch's Avatar
    Oct 2008
    I can just see a shop with every machinist crying their eyes out.
    Bob
    "Bad decisions make good stories."
    Registered fizzissist's Avatar
    Apr 2006
    Onion juice is fine for 303, but for 304 you need to switch to stewed tomatoes.
    For 316, Lipton Chicken Soup (strain out the noodles) works well, with an occasional brush of tomato sauce.
    For 400 series, especially 430F, I run Hormel Chili, w/ Tabasco, 1:1.
    For the exotics, run Coors...the low boiling point of the alcohol takes the heat off very efficiently.
    Jello Pudding diluted with Roses Lime Juice in a spray mist is the best ticket for machining plastics.
    For tapping copper, use heavy cream.
    (...there. that should keep ya busy. ... and btw, one of the above is actually true)
    Jul 2005
    Quote Originally Posted by fizzissist View Post
    ...For tapping copper, use heavy cream.
    Lard, heavy cream, what's the difference?
    Registered WATERJET71's Avatar
    Apr 2011
    Quote Originally Posted by Geof View Post
    YEs I was going to say that. LARD the best cutting not only for taping But for fly cutting .. Just one thing MAke sure you eat before you star using it. You get really Hungry NO Joke. that's what we used to use back in the days.
    Apr 2006
    Can't use lard if you're machining kosher.
    Dec 2006
    Alcohol really should work pretty good, and leave no mess. I would guess a mist would be best. Probably not a good thing to have alcohol puddled up on a spark producing cut.
    Jess
    GOD Bless, and prayers for all.
    Aug 2007
    That story actually reminded me of a little story,, FYI, when cutting onions while cooking at home and your hands smell,, rub them under running water while rubbing a stainless steel sink,, the smell is gone for good instantly.
    1. Knee Mill on Mythbusters
      By Lionclaw in forum CNCzone Club House
      Last Post: 02-04-2007, 09:48 PM
