Results 1 to 5 of 5
Thread: Red vs White Lithium grease
    Jul 2010
    I've recently puchased some Schunk two jaw chucks that arrived with a white lithium grease. We currently use a red lithium grease on our old chucks. Does anybody know what the difference is and is one better than the other?
    Registered Shane123's Avatar
    Jul 2010
    the white lithium grease we use is food grade. dont know much about yours tho....
    Registered Particle's Avatar
    Sep 2011
    I was curious so I started googling around a bit. Red might be more viscous from what I can tell. Both red and white can be or not be food grade.
    May 2004
    Considering how many chucks I have seen run with no grease at all, any kind of grease is a good thing. Even hog lard if you have some.
    http://www.kirkcon.com/
    Dec 2003
    White lithium is used extensively in automotive applications, I just did a number on my ISS shaft, (intermediate Steering shaft) that was syringe of white lithium.
    Also in spray can for door hinges etc.
    It also apparently is moisture/water repellant.
    1. Problem- white marking
      By wtgunther in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-13-2011, 03:02 AM
    2. Newbie- Lithium Grease?
      By Robotics Guy in forum DIY CNC Router Table Machines
      Last Post: 08-19-2010, 09:30 PM
    3. Trying to machine Lithium Disilicate
      By JayH1119 in forum Glass, Plastic and Stone
      Last Post: 06-09-2008, 05:44 PM
    4. Copper is white?
      By lloyd778 in forum Casting Metals
      Last Post: 02-08-2008, 04:38 PM
    5. Tool Gray or White?
      By MrRage in forum General Metal Working Machines
      Last Post: 02-21-2006, 12:01 AM
