Results 1 to 1 of 1
Thread: spinner router options
    Registered Claudio.d's Avatar
    Sep 2011
    Hi everyone
    i am in the process of building a small table , the cutting area is about 16 inches square the actual space is 24x24 , i am using t-slot fo the frame and the xy screw are in a sealed box with nema 23 steppers .. I managed to bolt them to my frame, I have decided to make the y axis stationary and the x axis on ball slides on a 20mm rod, i came to this decision cause of the weight factor
    i plan to adapt the top portion of a lathe slide compound for the z axis
    travel is about 5 inches and plan to use 2 spinners (one at the time) :a motor connented to shaft with bearings and a high speed one... with and here is my question
    I came across a 30k rpm ,120v 5.3 amps surplus spinner used for scientific blending
    it has a 6 mm shaft and i am looking for a small chuck for it ...any suggestions? does anyone have one?
    it has a dual ac dc motor so i plan to use a speed controller on it
    Thank you
    Claudio
  1. Spinner 5-axis - Siemens
    By bluedemon in forum General Full 3D Metal Milling Machines
    Last Post: 01-04-2012, 06:05 PM
  2. LIMAC CNC Router options
    By limacchina in forum LIMAC CNC Router
    Last Post: 06-09-2011, 04:55 AM
  3. Need Help!- Spinner TC65 (Turning)
    By Johnpaulojr in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-29-2011, 08:29 PM
  4. Chip Spinner
    By madmac in forum CNCzone Club House
    Last Post: 02-04-2011, 12:10 PM
  5. What are the 2' x 4' router options?
    By Tom Brown in forum Open Source CNC Machine Designs
    Last Post: 12-31-2007, 07:52 AM
