If price is no object, then a good new lathe would definitely be best. But otherwise, it's like buying a car - what would you rather have: a new Hyundai or a used Mercedes? Even a new lathe can have problems, especially if it's a really cheap one, but they are different from the problems a used lathe will have, even if it was originally quite expensive. If you're getting a used lathe, take someone along who knows a lot about them, to check for worn ways, loose or chipped gears, odd sounds, etc. And if you're getting a used one, look for one that comes with a lot of tooling, since you'll need it, and it costs a lot if you're buying it separately.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
