Results 1 to 2 of 2
Thread: Mitsubishi AQX cutter
    Aug 2011
    Philippines
    I tried using the the manufacturer's recommended cutting condition and lowering it by a lot. it can cut the metal clean and without the sparking. but i creates a lot of noise and vibration. so is it normal for the machine to be that noisy and vibrating or it should be vibrating at all?
    Registered Shane123's Avatar
    Jul 2010
    i have found that the mitsubishi's like a lower axial cut and a deeper depth, so .25" axial and .5 depth, on a 40 taper machine. I run a hurco vmx42, only 3 years old. depending on my cut, i can get the machine to rumble a little, but its a 40 taper, not the most rigid machine out there.....
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 01-12-2013, 10:57 PM
  2. Need Help!- Mitsubishi Meldus 500m cutter comp help
    By jw12 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-15-2011, 12:22 PM
  3. Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding & Toolgrinding Machines
    Last Post: 09-13-2010, 01:25 PM
  4. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  5. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-15-2008, 09:06 PM
