Results 1 to 8 of 8
Thread: smooth surface finish by milling?
    Aug 2011
    CA
    Is it possile to get smooth or as close to mirrior as possible surface finish by milling or fly cutting etc? Or are there always going to be those cutting parts when you need to do more than 1 pass to clear a surface?
    May 2004
    "Smooth" is a relative term. What rA are you looking to get? Or microinch? Give us some clues. What material? What machine?
    I have gotten 32 or better finishes on aluminum and steel with face mills, almost always having to run coolant.
    http://www.kirkcon.com/
    Aug 2011
    CA
    Aluminum. Well I mean as close to a mirror finish and more importantly without the obvious streak marks due to the multi-pass of the end mill across the surface.
    Jan 2006
    Nice mold machining centers will give you a great finish.
    "http://www.youtube.com/watch?v=78ANHmWyFNs"]Kitamura Mycenter-4XiF Vertical Machining Center - Pipe Mold Demo - YouTube
    Jul 2005
    All you need is a six figure sum of money floating around in your back pocket.
    The difference between machines that can produce an almost mirror finish and those that cannot is simply greater rigidity, greater alignment accuracy and better bearings both on the spindle and guideways. Although that is a big 'simply'.
    On manual machines the most common cause of the streak marks is mis-alignment of the spindle centerline with the travel of the table. Then comes table wobble due to non 'perfect' guideways. If you have these optimised, which can be tedious but possible, chances are you will start to see regular imperfections that I am sure are due to bearing inaccuracies.
    On lower cost CNC machines it is possible to get extremely good surfaces by moderating the feed. On these machines streaks or swirl marks are often visible at the start of a surfacing pass and they diminish along the travel. I ascribe this to the entire machine flexing which the impetus of accelerating the table up to the feed rate.
    Mar 2006
    There are a few tools that burnish surfaces. Rollers, smooth diamond "buttons" and wiper inserts on milling cutters. Ask your tooling sales guys, they should know their products capabilities.
    Dick Z
    DZASTR
    Feb 2009
    We have measured a 4 right off a dura center Mori Seiki with a 6" shell mill. Looks and actual finish don't always coincide however. We do a lot of optics turning here, so what is a good finish?
    Jun 2008
    canada
    Flycutter
    I have had good success on aluminum by dialing in the machine head and flycutting with HSS using WD-40 as a cutting oil. The finish should be dull gray not shiny, shiny and orange peel finishes indicate that the cutter is dull and rubbing. A few strokes with scotchbrite should remove any cutter marks.
    Hope this helps.
    Colin
    1. Need Help!- Achieving a smooth finish on a concave surface
      By Ariel6789 in forum SolidCam
      Last Post: 09-21-2011, 12:39 PM
    2. milling surface finish
      By mkhairi in forum CNC Swiss Screw Machines
      Last Post: 08-20-2011, 01:51 AM
    3. Replies: 11
      Last Post: 10-13-2007, 02:03 AM
    4. Bad surface finish with 3-D milling
      By dylskee in forum Haas Mills
      Last Post: 06-14-2007, 07:09 PM
    5. Surface finish after milling a mold ?
      By Shizzlemah in forum Moldmaking
      Last Post: 11-24-2006, 09:31 PM
